Discussion topic: No Wi-Fi
Message posted on 31 Oct 2025 07:49 PM
No Wi-Fi
Ni wifi, disconnected and switched back on but still not working
Message posted on 31 Oct 2025 07:52 PM
Re: No Wi-Fi
@CHDH1
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
Message posted on 31 Oct 2025 07:53 PM
Re: No Wi-Fi
@CHDH1 Is it NO wireless wi-fi or NO Internet broadband? What is indicated on the sky Hub for you!
Message posted on 31 Oct 2025 09:23 PM
Re: No Wi-Fi
Slow flashing green light on hub
Message posted on 31 Oct 2025 09:28 PM
Re: No Wi-Fi
@CHDH1 See post 2 from @Daniel0210 and the link about the lights!
