Discussion topic: No Wi-Fi connection
Message posted on 28 Jan 2026 07:25 PM
No Wi-Fi connection
Still no Wi-Fi connection - been down since 4.30 pm on 27 January. I do not have green lights on my router. Have turned off and on at least 15 times since I was told the issue had been resolved today. Please help - essential I have it for work
Message posted on 28 Jan 2026 07:28 PM
Re: No Wi-Fi connection
@Sandra1867
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
