Discussion topic: No WIFi working
Message posted on 09 Jul 2025 07:30 AM
No WIFi working
I have tried to connect, reset all devices and still no connection, App says all working in my area but it's not, we had an outage yesterday evening and I think it's the same again now. Can't even connect my noble to the WiFi
Message posted on 09 Jul 2025 07:38 AM
Re: No WIFi working
@PJD1961
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
