Discussion topic: No ONT box at new place
Message posted on 08 May 2024 07:23 PM
I'm moving to a new place and I've just upgraded my wifi I have a fiber cable running in to the home but there is no ONT box inside only a master socket will an engineer come and fit one on my activation date?
Message posted on 08 May 2024 07:25 PM
Re: No ONT box at new place
Enter your new full postal address in the link below and copy and paste the notes below the table
Message posted on 08 May 2024 08:11 PM
This is what it says :
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG partial Direct In Ground.
ONT exists with no active service. A spare port is available. A new ONT may be ordered.
Message posted on 08 May 2024 08:17 PM
Are you the first person at the new address. If not the previous occupant may have taken it with them
Just to be sure below is the ont
When is your activation date and were you told it would be remotely activated ?
Message posted on 08 May 2024 08:17 PM - last edited: 08 May 2024 08:25 PM
So Openreach has installed an ONT at some point. I'd suggest having a good look for this (not necessarily in the vicinity of the master socket) or evidence that it's been there: typically that would be a thin white flexible lead with an oblong green jack and a pair of screws low down on a wall near a power socket, plus possibly a circular white plastic cable entry cover.
Message posted on 08 May 2024 08:23 PM
on my email it says that my line will be activated without an engineer having visit.
Message posted on 08 May 2024 08:25 PM
As @TimmyBGood says have a good look around for the ont as shown in the photo in my previous post. However if the fibre cable just terminates then someone may have taken it
Message posted on 08 May 2024 08:27 PM
Okay ill have a good look but if someone has taken it what should i do then?
Message posted on 08 May 2024 08:28 PM
When are you due to be activated ?
Message posted on 08 May 2024 08:29 PM
Tuesday the 14th may
Message posted on 08 May 2024 08:32 PM - last edited: 08 May 2024 08:33 PM
Yes: that's because Openreach records show an ONT has been present: unfortunately these do sometimes get removed by previous occupants when they moved out.
It may be that Sky cannot book Openreach to replace the ONT until after the activation date.
Openreach will not install a new ont until activation day has been and gone.
Get back to us on activation day so that we can escalate this to sky
Message posted on 08 May 2024 08:33 PM
Okay ill update you. Thanks alot @cookiemonsteruk @TimmyBGood
Message posted on 14 May 2024 08:08 AM
Wifi has just been activated but didnt manage to find an ont box anywhere.
Message posted on 14 May 2024 08:17 AM - last edited: 14 May 2024 08:19 AM
Presumably that means you've received the Openreach text, which notifies they've built the external circuit. Without an ONT that's fairly meaningless, but at least you should now be able to book its replacement.
