Discussion topic: If my wifi box is also arriving
Message posted on 14 May 2024 09:49 AM
Hi im new to sky and received my sky stream box yesterday, i was just wondering if i had a wifi box on the way aswell?
Message posted on 14 May 2024 09:53 AM
Re: If my wifi box is also arriving
@KateHalliday Broadband connection take a minimum of 10 working days to be connected from placing the order, it isn't provided at the same time as your stream puck (as you posted in the stream forum).
Message posted on 14 May 2024 10:18 AM
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
