Discussion topic: No Internet connection
This message was authored by: Davepatmore
I need help with my Internet connection, I have  tried numerous instructions, still not working,
Re: No Internet connection
@Davepatmore
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
