Discussion topic: No Internet connection
This message was authored by: I2660
Hub not working . Stating no Internet connection. I have tried all wires etc as required but still no connection...this has been like this since yesterday 18th November 2025. Please can can someone sort this... Kind regards Ivan serheunik
Re: No Internet connection
@I2660
We can't sort it. We are customers like yourself.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
