8
This discussion topic has been answered Discussion topic: No Internet connection
This message was authored by: murphy+1955
Only got two green lights and one orange light on my hub
Re: No Internet connection
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
This message was authored by: Sameel1
Same since last hr
Avatar for murphy+1955
It back but miss the good bit ?
Don't know what going on with Sky at the moment. Not happy with them ??
This message was authored by: 1jaggers1
WHAT DI I DO- NO INTERNET CONNECTION
@1jaggers1
Try running this line test to see if it finds any faults:
If this is of no help give Sky a call to report it to them.
Oh my, my.....how clever you sound and easy you make it apear to be. I struggled with the system, but felt more like tripping over my toes with this. I am such a techno phobe, I am hesitant to try anything to resolve it, fearing to increase the fault instead. But, I appreciate how others reach out to assist in any way. many thanks, jaggers
@1jaggers1 Have you managed to change over to the white sky Max hub as yet, that is supposed to make it easier for the likes to check via the mobile app what is going on, although it does not always get it correct!
This message was authored by: Adam96
How do I Reset Router does the Router open
