Discussion topic: No Internet connection
Message posted on 22 Apr 2025 07:24 PM
Message posted on 22 Apr 2025 07:29 PM
Re: No Internet connection
@Sandy9999
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
