Discussion topic: No Internet (again)
This message was authored by: MBk1
No Internet (again)
Just returned home to find no internet, this seems to be a regular occurrence. Maybe need to change supplier
Re: No Internet (again)
@MBk1
As this is your first post we don't know any history to this, or what you've tried.
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
If there's a fault on the external circuit then any other ISP using the same network would inherit it.
