2
This discussion topic has been answered Discussion topic: No Internet again!!!
This message was authored by: JenniC88
Internet has gone down completely, this is happening at least once a week. Ive checked connections on the app and says its all working but its not!
Re: No Internet again!!!
@JenniC88
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
