Discussion topic: No Ethernet
This message was authored by: Arron89
No Ethernet
I have just joined sky I've had all the equipment delivered but I have no Ethernet cables?? Do I buy these myself or should they have come with the box etc..
Re: No Ethernet
@Arron89
Has your line been activated?
Sky would normally send out an ethernet cable (conversion kit) for full fibre fttp .however you can buy a category 5e cable in argos, pcworld etc
Avatar for Arron89
Level 0 icon
Re: No Ethernet
Someone from openrrach came out but sky hadn't sent the router so he couldn't set anything up he just I stalled a box and said when the router comes to just plug everything in.. the router had arrived but there's no cables just the sky box and the power lead
Re: No Ethernet
@Arron89
Sky doesn't ship ethernet cable with the Hub.  Does the new box on the wall have LEDs?
Re: No Ethernet
@Arron89
Has an ont been installed or are you still using the old mastersocket
