Discussion topic: No Ethernet connection in my house
This message was authored by Malook This message was authored by: Malook
Hi,I have moved to a house which is fairly old and does not have any Ethernet connection to connect my broadband,I only have coax cable here.
Please can somebody suggest what to do!
Re: No Ethernet connection in my house
@Malook
What sky package have you gone for
Superfast fttc or ultrafast fttp
@Malook  Have you informed Sky you have moved?   When is the connection for broadband meant to be taking place?
It would help also to identify which services are available at your new address.  https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome
No commonly available UK domestic broadband is delivered over Ethernet.  Do you mean there's no phone cabling arriving at the address but there may have been a Virgin (coaxial cable) connection?
