10
This discussion topic has been answered Discussion topic: No Connection
This message was authored by: Luca1808
No Connection
I have not internet connection
red internet light
red voice light
green power light
green WiFi light
I have already unplug/plug power cable and telephone socket cable
still not working
Re: No Connection
@Luca1808
If you are still having a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
This message was authored by: _Jayjay_
Re: No Connection
I have the same issue, Internet went down about 00.45 un plugged every thing and rest it and all I have is a slow flashing green light on my modem
Avatar for Luca1808
Re: No Connection
When I test the connection it is saying everything is ok
still 2 red lights and no connection
This message was authored by: Simon339
Re: No Connection
Same here, Internet went down Bohr half an hour ago, router won't connect despite restarting everything. I'm in Rugby
This message was authored by: Pamingham2002
Re: No Connection
I have the same problem. Can't get wi fi
This message was authored by: DE89
Re: No Connection
Same here ! Green light on the hub no WiFi and when I connect ask me go check the connection of the hub
Re: No Connection
All
Any broadband issues between midnight and 7am could be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
This link provides information about the coloured lights you may see on the various hubs
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
Avatar for Luca1808
Re: No Connection
AGAIN no connection today
still 2 red lights and 2 green lights
Avatar for Luca1808
Re: No Connection
Thank you
Re: No Connection
@Luca1808
Avatar for Luca1808
Re: No Connection
Thank You
