Discussion topic: No Broadband
Message posted on 29 Nov 2025 02:28 PM
No Broadband
Hi,
my broadband went down yesterday afternoon. 28/11/25. Sky said there was a problem in My area. This morning there is still no broadband but now sky are saying there is no problem in my area. Any help please??
Message posted on 29 Nov 2025 02:51 PM
Re: No Broadband
@karlwingrove
Try rebooting your hub in case that fixes it. If not, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Message posted on 29 Nov 2025 05:59 PM
Re: No Broadband
Thanks. I've contacted them. Think there is an issue that they didn't know about. Still not fixed but hopefully they will sort it out now.
Message posted on 29 Nov 2025 06:01 PM
Re: No Broadband
@karlwingrove
Sky usually quote 2 WORKING DAYS as a potential fix time due to the service level agreement in the UK between ISPs and Openreach for fixing a fault. Openreach claim to be successful within that timeframe in about 85% of cases.
Some repairs take longer, for example when a pole or cabinet has been damaged or Openreach need to dig the road up (after getting permission from the local council).
