Discussion topic: No Broadband
Message posted on 19 Nov 2025 01:28 PM
No Broadband
Hello we have had no broadband supply since Monday morning which means we have no land line no wifi calling and very lmt tv coverage could you please tell me when this problem will be resolved Many Thanks
Message posted on 19 Nov 2025 01:30 PM
Re: No Broadband
@fairwinds12
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
Message posted on 20 Nov 2025 11:15 AM
Re: No Broadband
- They don't care! No notice of major outage of work done by open reach. They just rocked up on Monday, without notice and cut off the internet and phone, 4 days now! Discussing service, I'm definitely changing provider. Not happy!
Message posted on 20 Nov 2025 11:27 AM
Re: No Broadband
@Dj+E @Unless you're fortunate enough to be in an area with either access to Virgin or an Altnet who have run their own cable to your street, any other ISP you move to are still likely to be using the Openreach infrastructure, so you'll be in exactly the same position.
Sky Q, 2 mini boxes, booster and full fibre gigafast. Good WiFi coverage throughout a 4-bedroom house!
Message posted on 20 Nov 2025 12:19 PM
Re: No Broadband
@Dj+E
This link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk for UK customers.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when Sky are notified of the fault, you will become eligible for it.
From Ofcom’s website:~
If your broadband or landline service stops working, you will have to report the fault to your provider. If the service is not fixed after two full working days, you would not need to ask for compensation or contact your provider again, as your provider has systems in place that mean you will start receiving compensation automatically if the repair takes too long.
This auto compensation is applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (from 01/04/25 the new rates are £9.98 per day)
▫️There is no equivalent scheme in place for customers in the Republic of Ireland.
▫️There is no automatic compensation for TV services affected by a broadband problem.
▫️Sky broadband being discussed here is a domestic service therefore whilst it's fine for customers who work from home to use it for that purpose they won't receive additional or quicker support.
