Discussion topic: No Broadband connection
This message was authored by: Rhodri67
Connection to Bradband
Re: No Broadband connection
@Rhodri67
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
