Discussion topic: Nightmare Broadband/wifi
Message posted on 23 Oct 2025 12:41 PM
Everything connected to my wifi keeps crashing, despite Sky's "diagnositc" tests suggesting all's well. Trying my hardest to speak to a human @ Sky is more difficult than I could imagine and I'm supposed to be a Platinum VIP member!
Message posted on 23 Oct 2025 12:42 PM
Re: Nightmare Broadband/wifi
@Morse666
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
