Discussion topic: New hub
This message was authored by: Lufcandrew
New hub
I just ordered my fiber to be installed on the 8th may but my hub has only just been sent what will happen if it dont arrive before the engineer on Friday
Re: New hub
@Lufcandrew
It should arrive before the 8th May but on the off chance it doesn't the fibre line can still be setup as all you will need to do is to set the hub up yourself by plugging it into the mains next to the ONT that will be installed in your property then connect them up with the supplied ethernet cable.
