Discussion topic: New equipment not working.
Message posted on 20 Mar 2025 12:46 PM
I had a new router connected earlier this morning, it worked for a few minutes, now there's nothing, no tv, WiFi or internet. The Sky WiFi is not showing on my phone settings. The LAN light is flashing off and on, when it's off the power light on the router goes red. I was also told that the Virgin signal would be on until midnight but it has been switched off.
Message posted on 20 Mar 2025 01:07 PM
Re: New equipment not working.
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 22 Mar 2025 06:14 PM
Hi, Sky replaced my router with a brand new one. It works perfectly with all four lights glowing green! The WiFi works fine on my phone as long as I am fairly near the router, I am currently sitting on my settee on 5G with the four green lights glowing green about twenty five feet away. As for my tv ( about the same distance away) it picks up the WiFi signal long enough for me to put the password in and then the connection cuts out. The equipment was put in by MJ Quinn on behalf of Openreach. I have just re-watched their customer installation video which says they should demonstrate one of my devices working, but they didn't and left after showing my the four green lights on the router. The main reason I got Sky was to watch the F1 motor racing but I won't be doing that this weekend.
