2
This discussion topic has been answered Discussion topic: New WiFi password not accepted
This message was authored by: Mikey124
I've set up a new broadband router. I have a code to scan which auto joins the WiFi no password needed. I cannot do this on tv's and have input the new password exactly as it appears on the WiFi card. But it will not accept and says it is incorrect
Re: New WiFi password not accepted
@Mikey124
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as shown on the hub itself so use upper case letting if required.
@Mikey124
Avatar for Mikey124
Thank you. It really was that simple. I had 1 letter incorrectly
