21 Dec 2023 08:26 PM
I have recently seen a new wi-fi connection appearing on my available networks, with an almost identical name.
My wifi name is similar to the following: SKYASDFG, but I now see that connection and another one with exactly the same name but with a number 2 added on the end: SKYASDFG 2
Not sure if this is something I need to be concerned about?
Any advice gratefully accepted.
GC
22 Dec 2023 08:06 AM
Posted by a Superuser, not a Sky employee. Find out more@Gerry+Crow most likely explanation is someone has split the 2 wifi bands on your hub to connect a device tgat doesn't like dualband SSIDs. Is thatva possibility?
22 Dec 2023 04:58 PM
Thanks Chrisee,
None of us in this house would know how to do that, but lots of devices now seem to make chnages automatically, so perhaps that is what has happened.
GC
22 Dec 2023 06:25 PM
Posted by a Superuser, not a Sky employee. Find out more@Gerry+Crow no to split wifi bands has to be done manually. However some devices can act as wifi hot spots so that is a possibility as while Sky Q boxes do that they use the same SSID.
