Discussion topic: New Sky Fibre
This message was authored by: JarrodMelville
New Sky Fibre
I have recently upgraded to Sky Fribre 150 from an existing sky wifi package. Now I have numerous problems connecting in my office and frequently it stops working. Downloading documents, which is essential for me, takes forever. I have paid to upgrade but the relaity is I am now experiencing a worse wifi than I had before.
Re: New Sky Fibre
@JarrodMelville
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Re: New Sky Fibre
@JarrodMelville What happened when you upgraded to Fibre, the hub moved to a new position, to suit the connection, did you also updrade to sky Max hub or keep all of the original equipment!
