Discussion topic: Fibre
This message was authored by: Speckledhen
Fibre
We had the engineers round to fit fibre, they have put a box on the inside wall for when the line outside is sorted. When that is fixed and running, will we still need to use the sky hub box or will the WiFi work with just the fibre box???? Thanks
Re: Fibre
@Speckledhen The hub you have now get's connected to that new Fibre ONT box via an Ethernet cable connected wan port/lan4 on the hub to the lan on the ONT. Old DSL cable from the hub to the Master phone socket gets removed and disgarded.
If you have the old SR203 hub, sky will be sending you out a short 1M Ethernet cable for connecting both! Landline phone if you have and are using will connect into the back off the hub!
