Discussion topic: New Sky Fibre - wifi issues
This message was authored by: Coldurs
Hi there,
we recently upgrade to new Sky Fibre. Unfortunately, where the engineer had to install the new fibre cable means the other end of our house doesn't have reliable wifi. Can Sky provide a wifi booster to resolve?
thank you.
Re: New Sky Fibre - wifi issues
@Coldurs
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Avatar for Coldurs
Thanks. Will take a look at the links later on.
