Discussion topic: New Openreach fibre optic cable
Message posted on 15 Aug 2025 06:02 PM
Has anyone experienced a changeover from old (BT) cable connections for broadband to the new Openreach fibre optic cables? What should I be aware of in order to make the changeover without impacting on my Sky broadband service? How do I prepare? Do I have to contact Sky?
Message posted on 15 Aug 2025 06:29 PM
Re: New Openreach fibre optic cable
@SheffieldTyke See if the sky help link is any use for you!
What’s Full Fibre broadband? | Sky Help | Sky.com | Sky Help | Sky.com
Message posted on 15 Aug 2025 08:38 PM - last edited: 15 Aug 2025 08:40 PM
Yes, somewhere around fifteen million households. Note the old coppy cables are Openreach too: 'BT' is an ISP in competition with Sky.
There's inevitably some impact.
An order must be placed through an ISP: nothing happens otherwise.
Message posted on 15 Aug 2025 08:41 PM
Hi Thanks for the link.
It mentions the Optical Network Terminal. But it says they - Sky - will fit one. However, there is confusing information out there, not helped by the flat management company not providing clear information on what Openreach will actual do.
I have seen online information that says Openreach will install the ONT. If that is the case will I just be able to unplug from the old socket and plug it ionto the new? Or do Sky have to get involved? Will they need to send an engineer (costing how much?) or can they simply test my new connection remotely after I have switched over?
https://www.openreach.com/help-and-support/full-fibre-broadband-installation-checklist
Message posted on 15 Aug 2025 08:46 PM
@SheffieldTyke As you mention flat, that is an MDU type fibre, if already done by OR then Fibre will be sitting outside in a junction box above your main entry door. Check the BTW site it will say if Fibre is there or not! Use the Address checker, 2nd box top left click on it all the fields change, enter all as required and it will tell you the state off play!
Thanks for the link. Some useful information there. Wish me luck when Openreach come to do the work in the small block of flats.
Message posted on 15 Aug 2025 08:54 PM
Perhaps note that in flats the individual residents have rather less choice, because Openreach needs to negotiate with the freeholder.
