Discussion topic: New Broadband HUb Activation Code not received
Message posted on 30 Apr 2026 08:01 PM
I received a new SKY hbroadband hub and was informed not to activate it until i have received the activation code. I was informed that the code would be on the box that the hub arrived in. WRONG, there is no code on the label or box. The label is different to the one shown on your help page. I am unable to proceed without this code and have no Idea what i have to do now. I am a 79 year old widow and need help with tecnical things.
Message posted on 30 Apr 2026 08:06 PM - last edited: 30 Apr 2026 08:18 PM
Re: New Broadband HUb Activation Code not received
@Cheryl0109 Broadband hubs do not have or need an activation code, I presume you mean activation date?
Is this a new install or a replacement hub?
If a new install what is your Go Live date with Sky?
Message posted on 30 Apr 2026 08:09 PM
yes I do mean an activation date. This is a replacement hub which SKY advised me to have.
Message posted on 30 Apr 2026 08:11 PM
You can start using that straight away as it is just a replacement so there is no activation date as you are already a broadband customer.
Message posted on 30 Apr 2026 08:15 PM
IF the hub is just a replacement and I am a current user, is it neccesary to change my SKY password?
Message posted on 30 Apr 2026 08:19 PM
@Cheryl0109 The new hub will have a different wifi ID & password, both will be on the back of or underneath the hub.
Message posted on 30 Apr 2026 08:23 PM
The only way you can get around this is to login to the new hub and change the network name and wifi password to the same as the old one had.
