Discussion topic: Network security key
Message posted on 26 Dec 2023 11:38 PM
I have no idea what my network security key is or where to find it on my sky internet box as I'm trying to connect to the internet on my laptop and it keeps on asking for the network security key code
Message posted on 27 Dec 2023 05:50 AM
Re: Network security key
If you are a Sky Broadband customer then usually it is printed on the back of your broadband hub somewhere.
Message posted on 27 Dec 2023 09:13 AM
All ISPs put those on a printed label on the router: some duplicate this on a separate printed sticker.
Occasionally there's a hiccup during manufacturing and no such label is attached: if that happens you'd need replacement hardware.
Message posted on 22 Mar 2024 12:43 PM
My broadband is currently down in my area but I can use my phone as a connection, however when I try to do this and enter the network security key it keeps telling me its wrong, the only info I have are, WiFi name, password, serial number and a pin number I take it I should use the pin but even that says its wrong, any ideas anyone?
Message posted on 22 Mar 2024 01:28 PM
PIN is only applicable where the client device is using WPS with a PIN option (which has largely been removed as an option as it's inherently insecure). Most devices will use network name (SSID) and password.
Message posted on 22 Mar 2024 03:57 PM
@skinnerfam2023 It may be worth finding a pin and doing a hard reset on the little button at the back of the router, hold and press it in for at least 10-15 seconds, then try and re-connect your devices.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Message posted on 22 Mar 2024 04:10 PM
Thank for the attempted assist but that all failed, my son got me to the right spot for me to find what was needed on my phone.
