Discussion topic: Network problems
Message posted on 08 Feb 2025 09:20 PM
Network problems
My sky mini keeps losing it network connection
main tv ok but both mins playing up 😵💫and solution please 🙏🏻
Message posted on 08 Feb 2025 09:53 PM
Re: Network problems
Sky loans booster hardware to solve Mini box network issues.
Message posted on 26 Jan 2026 01:51 PM
Internet keeps stalling when watching tv. Also mobile, alexa and separate tv keep losing connection. I have spoken to someone but we keep getting cut off
Message posted on 26 Jan 2026 02:12 PM
@Susanlarkman1 Are you getting cut off using your landline calling to sky? If so you may need to try calling them another way, what do you see when you look at the sky hub lights! See the link below about that especially if your landline plugs into the back off the sky Hub!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
