6
This discussion topic has been answered Discussion topic: Network issue
This message was authored by: Harishbalda
Network issue
Hi there, we are facing network issues in west Calder parkhead area.
Re: Network issue
@Harishbalda
As you haven't replied I an going to presume your issue is broadband related.
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
Re: Network issue
@Harishbalda
You have posted this in the Sky Go forum so are your issues to do with Sky Broadband ?
Re: Network issue
@Harishbalda
This message was authored by: NikhilSMedackal
Re: Network issue
Hi there, we are facing network issues in sandringham road Petersfeild
This message was authored by: Vic54
Re: Network issue
My broadband is running really slowly so my security cameras aren't loading and my alarm app isn't loading
Re: Network issue
@Vic54 pretty random addition to an old thread but most likely issue isnt with your broadband connection but simply poor WiFi in your property. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
This message was authored by: Daniel444
Re: Network issue
I  m reset router and problem stop time is
