Discussion topic: Network down
This message was authored by: Skyisrubbish3
Network down
Lost network connection on tv /apps and mobiles,  laptops no internet to our house even though the router is showing green lights. Done all the checks, nothing responding this is a regular occurrence but the WiFi checker is showing all is fine but it's not
This message was authored by: Av14n
Re: Network down
Having the same issue, was watching ITVX then lost connection to wifi, online saying no connection issues however box is showing amber light for internet - have turned plug off and reset the box twice but no change. We have also been getting lower than promised download speed recently also
This message was authored by: Aj79
Re: Network down
I have no wifi light on and no connection
Re: Network down
@Aj79 @Av14n
If it's happening at the time you've posted it's possibly maintenance related. This is done overnight to minimise disruption as most customers are asleep. If it's not back up by the time the phone lines reopen call Sky to report it.
▪️I AM NOT A SKY EMPLOYEE ▪️
Re: Network down
@Skyisrubbish3
Your issue started a little early to be maintenance. If you haven’t done it already use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
Avatar for Skyisrubbish3
Re: Network down
I have done all the checks and tests required and says there isn't a problem, but there definitely is as we have connection on sky box's, mobiles or laptops
Re: Network down
@Skyisrubbish3 if the Sky hub shows it has lost connection and tge service checker is still not telling you Sky arexaware of the problem call them to report it.
