Discussion topic: Network connection
This message was authored by: Roberthulley
Network connection
My WiFi is ok but my box has no network connection
Re: Network connection
@Roberthulley donyou mean your Sky hub has lost its connection to the exchange? If so run the Service Checker in the My Sky app over a mobike connection as that will tell you if Sky are aware of an issue affecting your line. If it doesn't call Sky to report the fault.
