Discussion topic: Network connection
This message was authored by: Becks151
Network connection
I have no network connection,I have done all the steps,turned off/on everything more then once and still not working
This message was authored by: bemak187
Re: Network connection
@Becks151What lights are on your router?  Can you still see the wifi networks but dont have any internet connection or can your devices no longer see the wifi network itself?
Avatar for Becks151
Every light is on on the router,it's on my sky box saying no network connection (cross on)
@Becks151 standard trouble shooting is to power down the Sky box and then allow it to reboot. If the conection is not re-established follow the on screen prompts to reset the network connection.
Avatar for Becks151
I have done this lots of time and still got a cross at side of network connection,followed all steps on screen and still no joy
Avatar for Becks151
All lights are on router,but says no network connection on my sky box,followed all steps on TV what it says do but says can't connect to router,iv pressed & holded the WPS button on router aswell
