Discussion topic: Network connection failing
This message was authored by: KiKi86
Hi,
my network connection is failing from sky Q box to hub which means I cannot use the apps etc on the tv. The router is showing all green lights and all other Wi-Fi products are working in the house.
Re: Network connection failing
@KiKi86 it maybe at the limit of the range if so call Sky who should offer to send you a wifi booster which is installed halfway between the hub and the Q box.
