Discussion topic: Network Security Key
This message was authored by: Kayos
I've read many replies on where to find my SKY Network Security Key. It is NOT on the router or the accompanying card. Please, someone, either tell me what the key is or how to find it elsewhere.  I do not see anything that says Security Key.
Re: Network Security Key
@Kayos  No one here or at Sky can tell you what the wifi password is, have you checked both the back & underneath of the hub?
Avatar for Kayos
Level 2 icon
YES, I just need to know where or how to find it.
Avatar for Kayos
Level 2 icon
Hi again, is the password also the security key?
Yes
This message was authored by: Polly441
Thank you I will try my password. My laptop has an old windows I might have to upgrade. Thank you for your help.
