Discussion topic: Network Problems Every Day
Message posted on 05 Oct 2025 03:17 PM
Since last Thursday after about 5 hours on the internet I lose my broadband. I get the message "Low Network." I've tried on my spare laptop and I get the same message. The only way to clear it is to do a full network reset. I have tried my laptops connecting to a friends Broadband and there is no problems.
I've rang Sky twice to be told its my laptop at fault but I don't think it is. Two separate laptops with the same problem. I've done all the line tests and reset the router but its just happened.
Not at all happy!
Message posted on 05 Oct 2025 04:14 PM
Re: Network Problems Every Day
@Geordie_Alison What is a full network reset?
Message posted on 05 Oct 2025 04:24 PM
I have to reset all the network adapters on my laptop then it's fine for the rest of the day.
Message posted on 05 Oct 2025 04:28 PM
@Geordie_Alison Got it, so it does sound like you have a laptop issue with them both! Doing that fixes the issue, it's your laptops!
