Discussion topic: Need new router
Message posted on 06 May 2025 12:29 PM
Need new router
I am FTTP user, My Netgear Nighthawk died on me over the weekend. Currently using the SR (unknown what version) I am looking for a new router and looking at ASUS as many people have replace that without their SR router.
my budget is £200 max I have 2 puck, 2 macs, 6 mobile devices, ps5, CCTV and ip cameras.
Message posted on 06 May 2025 01:16 PM
Re: Need new router
@Danny2610 different users have different needs with Stream pucks you may find a multi unt Zen WiFi set up best while as a gamer you may need QOS if other members of the family watch TV while you are gaming. A lot depends on the layout of your home and even how it is built. Settling for slower wifi significantly reduces the costyour budget limits you to WiFi 6 or 6E from a quick check.
Asus units seem to support DHCPv4 option61 that works with all Sky's UK services.
Message posted on 06 May 2025 01:25 PM
Re: Need new router
I don't game as much as usual do. I live is a small semi-detached house, signal won't be and issue most of the wired devices are thru powerlines.
Message posted on 06 May 2025 01:43 PM
Re: Need new router
Asus has been flawless for me
Message posted on 06 May 2025 01:54 PM
Re: Need new router
@Danny2610 this page maybe a good place to start https://www.techradar.com/news/best-asus-router
Message posted on 06 May 2025 03:35 PM - last edited: 06 May 2025 03:36 PM
Re: Need new router
How are you finding the powelines?
I have a TP-Link router and it covers the 3 bed double storey house but my sons loves his online games and uses powerline for low latency. I have a AV1000 using but the speed never goes beyond 120Mbs but Wi-FI is 450Mbs+ in same lcoation.
If I was to replace the TP-Link router then would go for a 2 unit triple band mesh. The 3rd band bachaul makes a huge different..but I don't think £200 will cover it.
Message posted on 07 May 2025 10:01 PM
Re: Need new router
I just ordered ASUS RT-AX58U V2
Message posted on 08 May 2025 07:36 AM
Re: Need new router
@Sayek powerline adapters never deliver the rated speed in my experience you are lucky if you get 30% but out right speed is less important for gaming than low jitter and latency.. Online gaming itself only uses something around 10Mb/s but of course loading updates etc will use more. Whether your son's experience would be improved by getting a decent whole home wifi system is debatable as it all depends on the layout and type of construction of your home.
