Discussion topic: Need a wi fi booster
This message was authored by: Scotty4321
I need a wi fi booster but I honestly cannot be bothered phoning them. Is there a way to order one on line?
Re: Need a wi fi booster
No, you need to call.
Avatar for Scotty4321
Oh boy. I'll need to set aside two hours to phone and literally plead my case. Customers service is **bleep** and so frustrating. Thanks for your reply. Thought it would be easy just to get one on the Sky page. Like everything else they make it difficult.
Got thru on chat to a human. Advice was to buy a compatible signal booster from Amazon. I despair
Now a new router has arrived. Don't know why. Confused
@Scotty4321 if you ordered Sky WiFi Max you would be sent a Sky Max hub if you did not already have one. Sky send out pod extender to match thh new hub if you call them.
I believe Sky max is another £6 a month.
This message was authored by: Rich1956
Had the same problem. Put in a compaint and was sorted evendually. Took 2/3 calls to the 'tech' team and after using the online chat and engineer was sent out. Fitted a new 'pod' extender but didnt really solve the problem. Looking at changing internet provider.
