Discussion topic: My wifi isnt working my sky tv wont connect and the line is showing a fault
This message was authored by: Adrian102
Wifi isnt working and broadband connection is showing a fault broadband router has a flashing green light
Re: My wifi isnt working my sky tv wont connect and the line is showing a fault
@Adrian102 Link below may assist you!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
