1
This discussion topic has been answered Discussion topic: My wifi is dropping out
This message was authored by: Firas1
Dear I live in [Removed]  ,recently my WiFi is dropping off can you please check the network and try if you can troubleshoot
thank you
Moderated to remove personal details.
Re: My wifi is dropping out
@Firas1
Your post has been temporarily removed as you've posted most of your address on a public forum. It will return after being moderated later.
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
@Firas1
