Discussion topic: My wi fi is weak
This message was authored by: Jonorr123
My wi fi is weak
My wi fi is weak when I work from home and in my daughters room.  I was once with BT and was provided 4 x boosters but you have only provided 1.  Can you please help or provide more to strengthen the wi fi around my home ?
Re: My wi fi is weak
@Jonorr123 you are not talking to Sky by posting in the forum you need to talk to Sky tomsee if thrybwill supply further boosters. However have you considered buying your own WiFi system? These need not break the bank and in general arecfar more reliable than systems supplied by ISPs. These need not be difficult to install if set up as access points as they connect tomthe Sky hub by ethernet cable.
