Discussion topic: My printer does not work on Sky hub
This message was authored by: Jonel
Message posted on 29 Nov 2024 04:10 PM
I just got a Canon TS3355 printer. It will not work on my new Sky router.
Find out more
Message posted on 29 Nov 2024 04:13 PM
Re: My printer does not work on Sky hub
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
