Discussion topic: My laptop keeps loosing connection
This message was authored by: Laptop25
Message posted on 19 Nov 2025 10:34 AM
Find out more
Message posted on 19 Nov 2025 11:28 AM
Re: My laptop keeps loosing connection
@Laptop25 most likely cause is poorcwifi signal level where you are using your laptop. Either move closer to the Sky hub or consider getting a booster.
