Discussion topic: My internet is down. Is there a problem
This message was authored by: KarenSad
My internet is down. Is there a fault
Re: My internet is down. Is there a problem
@KarenSad you won't find the answer to that on this forum. This is a public fourm where  Sky customers help other Sky customers.
I'd suggest using the service checker to see if it is reporting an issue: https://www.sky.com/help/servicestatus
Also check the steps on Sky's guide on how to test your broadband.
https://www.sky.com/pages/sky-com/test-your-broadband
If there is an issue you should call Sky and report it, as if the issue isn't resolved within 48 hours of you reporting it and its an issue outside your home, will be eligble from automatic compensation.
@KarenSad  Your post has been moved fron the Sky Go forum as your issue is with Broadband.
Have you tried running this test?  https://www.sky.com/servicechecker
