4
This discussion topic has been answered Discussion topic: My internet is Not working
This message was authored by: NatashaA2
My internet is not working and your app tell me it is and looks good this incorrect your app is lying
Re: My internet is Not working
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
This message was authored by: Jamwise
Same here. Router looks fine, can connect to the router but have 0 internet connection. App tells me everything is fine and working but it's not.
This message was authored by: Andy1234567
My Internet is down also. The test says all is OK . WiFi look OK. No Internet shown on router. Orrell / Bell lane Wigan.
This message was authored by: BGR
Same here no internet but the app says everything is working
