Discussion topic: My Wifi keeps dropping out
Message posted on 11 Nov 2025 03:04 PM
On a regular basis ( at least once a day ) My Wifi keep dropping out completely. i need this for work and it drops my Teams calls and is causing an issue
Message posted on 11 Nov 2025 03:08 PM
Re: My Wifi keeps dropping out
@Simon070175
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
