Discussion topic: My internet doesn’t work
This message was authored by: Stuart150
I have all green lights but no device had internet
Re: My internet doesn’t work
@Stuart150
If rebooting your broadband hub doesn't bring it back to life then try this:
If this is of no help give Sky a call to report it to them.
@Stuart150
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
@Stuart150 Switch your hub off to see if the internet signal connection get's re-established.
