Discussion topic: My internet doesn't work stable
Message posted on 29 Dec 2024 11:40 PM
It's not working properly, it usually down on 23.36 everyday.
Especially today.. internet outage occured today (29th of Dec) every 10 min between 21.00 and 23.30.
Unfortunatelly I've to sleep because it's not possible to use it, I'm tired to test my internet with Sky app.
Message posted on 30 Dec 2024 06:08 AM
Re: My internet doesn't work stable
@Eraycan check the leds on your hub and use this trouble shooter https://www.sky.com/help/articles/hub-lights-explained-start
Loss of connection at a fixed time is often caused by some timed event in your home like a heating system turning off.etc so check if something like that is knocking out the connection. While it can be an event outside your home that is rare and very difficult to sort.
Message posted on 31 Dec 2024 09:46 AM
Thanks for your advise, I shut down my heating system, I am going to observe it'll be helpful.
