Discussion topic: My internet doesn’t work from 2 week
This message was authored by: Jelana
My internet doesn't work from 2 weeks I would like to know reason
Re: My internet doesn’t work from 2 week
@Jelana
This is a customer ▶️ customer discussion forum where we try to help other customers. You haven’t actually contacted Sky by posting on here.
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
▪️I AM NOT A SKY EMPLOYEE ▪️
