Discussion topic: My internet connection
Message posted on 25 Sep 2025 12:04 AM
My internet keeps going on and off all the time I don't get a full hour of internet without it going off. I pay a full bill every month with my sky tv and internet it's nearly £90 I'm not willing to pay that amount with the service I'm having with the internet connection. If it's not fixed I will be cancelling my sky and going with a different service
Message posted on 25 Sep 2025 05:39 AM
Re: My internet connection
Threats to change providers is pointless here. l’m afraid you aren’t speaking to Sky Customer Services by posting here. This is a customer led discussion forum where we try to help other Sky customers.
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
